in reading the instruction book for the Pioneer DVD (DV-454/350) it says the following regarding DVD-R/RW compatability:
-unit will play DVD-R/RW discs that were recorded using DVD-Video format;
-will not play DVR-RW discs that were recorded using the Video Recording format
-unfinalised DVD-R/RW discs cannot be played
can someone pls explain that DVD-video format means and what are unfinalised discs?
does that mean if i burn a dvd using my Mac (or PC) I will be unable to play them in the DVD player?
many thanks
I am unsure what this video recording is. Probably something to do with stand alone dvd recorders. All dvds you burn on your computer will work as long as they are make properly.
Dvd Format Video is where you have Video_Ts and Audio_Ts folders.
If you are using nero to burn then place all the files .vob's etc into the Video_Ts folder. The Audio_Ts folder is empty. When you tell it to burn it asks you if you want to finalise the disk...You have to click yes to do so. I know my Panasonic wont play un finilised disks.....Not bothered by small problems...
Spend a night alone with a mosquito -
VIDEO_TS is DVD Format
VIDEO_RM is Video Recording format [ie ones you get from settop dvd recorders]
Its really easy to convert them over.... alll you do is...
copy the VIDEO_RM over to your HD. Rename as VIDEO_TS and reburn as you would normally do if you had a VIDEO_TS folder.
and you want to know what is even stranger......
VIDEO_RM seems to be compatible in every player EXCEPT Pioneer
strange huh
Pioneer 420k DVD player for canadians
By victoriabears in forum DVD & Blu-ray PlayersReplies: 47Last Post: 30th Aug 2011, 09:26 -
Pioneer DV-410V-K DVD Player need to make region free
By langer1 in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2009, 20:07 -
Need help please in making my Pioneer DV-410V DVD player region-free
By sasa66 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Feb 2009, 01:30 -
Philips vs Pioneer upscale DVD player, which one?
By hanugro in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Dec 2007, 04:08 -
Qustion Dvd Player - Pioneer Dv393
By zaptos in forum DVD RippingReplies: 2Last Post: 28th Oct 2007, 08:26
