Hi..
I was looking at a DVD at my friends house.. i noticed it wasen't an original. He put it in and startet it and i noticed that when he used his remote to select an "item" on the menu, like extras.. he marker just jumped over it. Like it was impossible to select. When i backup my DVD's
by removing the extras i can still click on them. A blackscreen appears for a couple of seconds (4-8). I'd like to still have the button there, but not being able to click it.
So my question is what program could i use to achieve the menu to act that way, and who? could someone direct me to a guide, or write a guide here? (Something not to complicated :) Thank you.
Results 1 to 10 of 10
I use CloneDVD,it's preview screen allows you to see what each item is before you delete them. Very easy to use. A program like Title Set Blanker will work with any compression program but has no preview so it's difficult to know what your deleting.
Your not even close to what i'm looking for.. When i removed the the extras. It's still possible to click on the extras buttons. that links to the title i deleted. in other word, linking to nothing, the dvd trys to find it, but can't, so a blackscreen appears. I want it to not be able to press the button. when you use the remote and try to select it the marker just jumps over it like there were nothing there.
..I want it to not be able to press the button. when you use the remote and try to select it the marker just jumps over it like there were nothing there.
yeah, DVDReMake is the best program for the job that I know of.
www.dimadsoft.com -
Here is the answer to your question.
https://www.videohelp.com/tools?tool=580#comments
DVDStripper will strip all the crap and then you can use MenuModder to disable buttons leading to the removed content
if you want the all in one package with more features and faster processing then I agree with the others regarding DVDRemake
How do I backup this movie and maybe change menus?
By leopardx in forum Blu-ray RippingReplies: 3Last Post: 6th Jun 2009, 11:10 -
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 10:30 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Remove extras and keep the original menus
By jujuandhuhu in forum DVD RippingReplies: 4Last Post: 7th Mar 2008, 09:55 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 10:27
