im renting an anime from netflix(full metal panic) and it cannot be read by my pc. other dvd's of mine work fine on it. the anime will work in my ps2 and other dvd players though.
when i put it in the pc, the green light goes on, the drive doesnt make any noises. and windows doesnt react to the disc. and i cant eject the disc, i have to put the paper clip through the hole to pop it out, after i push the tray the light still flashes for like 5 mins, then makes some click noise and goes to normal.
any suggestions to get this anime to work in my pc? its an HP a450n, xp pro, NTFS, DVD+RW 4x drive, just reformatted like 2 hours ago. i tried to update the firmware but for some reason, hp's update wont detect my optical drive
were you doing anything in the background when you were updating your firmware? If so, you probably ruined your drive.
no i never updated the firmware, other dvds still work perfectly fine. anime i borrowed from a friend seems to work in my drive also... and the full metal panic dvd works fine in my uncle's dvd drive
that was not what I asked. When you tried to update were you doing anything else as well in the background? Even surfing the internet while upgrading can torch your drive?
well, i dont think it installed anything, it just loads an exe and 'read contents of the package' and then it says the optical drive not found, your driver does NOT need an update, and i hit ok and it exits
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Restore a DVD+R that wont play
By ProfHiggins in forum MediaReplies: 10Last Post: 14th Dec 2009, 22:49 -
JVC Wont Play New DVD's!
By Raxxor in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2008, 13:02 -
LG DVB-T wont play DVD's
By scdom in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2008, 07:20 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 02:00
