  1. i wonder if one of you good people could help with some advice. i have an avi file of a foreign language movie , i also have a file of subtitles in a notepad form which list the subs and the time settings, is there any way i can put these subs onto the movie. many thanks
  2. install VobSub, then the subtitles will appear
    Apr 2002
    The State of Frustration
    Depending on the format of the text, Sub Station Alpha can load them and save them as an SRT, SSA, etc file, which can be converted into a SUP file with VobSub Resynch.
    Hello.
    Rio de Janeiro - Brazil
    If your target is a SVCD or DVD, you can use my tool DIKO:
    http://kvcd.net/forum/viewforum.php?f=79
