I'm trying to convert an .avi encoded in DivX but TMPGENC won't let me. I have all the codecs installed and it works with other divx files except for this one. This file runs fine in both Windows Media Player and GDivX Player. I tried to encode it using TMPGEnc V1.2a and it accepts and works. However, I want to convert it using a newer version. Is there a way TMPGEnc to accept any .avi file? Is there an option I can turn off or something? Please help.
Thanks.
Guest
Hi, get the same situation myself, the only way i've found around it (as a definate newbie) which may well be a totally wrong way to attack the problem is to take the file into virtual dub and compress it into divx 4.2 and then into tmpg, I think this worked for me, alternatively decode the sound and video seperately in virtual dub and output as uncompressed avi and a wav file which should both then load into tmpg although Im sure someone will advise on a better way to do it, as I am speaking from a few short hours experience.
Hope this helps in the meantime though -
If virtualdub has no problems dealing with the .avi try frameserving through virtualdub to tmpgenc.
Go into options, then environmental settings, then VFAPI plugin in there, move the directshow multimeda filter to priority of 5
that fixed it for me!!
keith
TMPGEnc Authoring Works 4, no audio with AVI files
By aln688 in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2010, 17:02 -
Checking avi file corruption
By Igniss in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2009, 10:43 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 11:36 -
Checking video files
By unknown12 in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2007, 03:32 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
