I,ve now used TMPGEnc to convert all my footage. It is now in M2V format. What else do I need to do to be able to burn it to DVD so that it is viewable on my standalone DVD. Is M2V another name for Mpeg2
Would I just burn these files, are they video AND audio?
Can I just drag and drop the M2V files in nero and burn to DVD?
Why is this so difficult.
Thanks in advance.
M2V is the extension for MPG video without any audio. You should have an audio file also. You take these files an put them into an authoring program such as TMPGEnc DVD Author and this will generate the proper format for DVD. Then your burn this authored file to DVD disc. You might want to study the guides to the left for more detailed information.
Thanks for the reply, I,ve tried downloading the trial version of TMPGEnc DVD author but I keep getting an error preventing me from installing the program.
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 07:22 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 18:13 -
join .m2v files?
By just in forum Newbie / General discussionsReplies: 5Last Post: 24th Nov 2008, 21:11 -
edit m2v files?
By SUPERIOR in forum EditingReplies: 2Last Post: 16th May 2008, 03:42 -
ts files into m2v or mpeg2
By vertical in forum Newbie / General discussionsReplies: 124Last Post: 21st Jun 2007, 14:12
