Hi all,
What I'm trying to work out here has all got to do with size. Why is it that, say, when I copy a dvd of about 100 minutes and DTS sound that I can fit it on a DVD-5 yet when I capture video from an analogue source of lesser time (say 10-20 mintues less) and with just simple stereo audio it is too big for a DVD-5 and has to be shrank to fit. I've been using WinDVD and capturing straight to mpeg with a total bitrate of 6800kbits/sec.
While it isn't so much a problem rather an annoyance, why is it so and is it just me or is there something I can do to fix it, ie lowering the bitrate (yet still keep dvd quality)?![]()
If your 'simple stereo audio' is a PCM .WAV file, then it takes up a lot of space compared to an AC3 audio or MPG-1 layer 2 audio. Take your video and check it with AVIcodec and you can see the sizes of the audio and video files. I use MPG-1 Layer 2 and it works well in most players. AC3 is better, but involves a little more work to produce.
well, I thought that might have been the prob but I've checked and the audio capture is done in mpg-1 layer 2 so......?
Maybe your DVD software is changing it back to PCM?
I'm using Ulead MediaStudio Pro and Ulead DVD Workshop, both are capable of producing AC3. No trouble at all. It's just a matter of selecting AC3 for output, but both cost quite a bit though.Originally Posted by redwudz -
Are you using Constant Bit Rate (CBR) or Variable Bit Rate (VBR). Those times are pretty close for CBR @ 6.8Mbps. VBR should give you more time.
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 18:32 -
How can I shrink down the running time of an audio file?
By darkzero297 in forum AudioReplies: 3Last Post: 16th May 2009, 12:07 -
Total running time
By mrcoolekin in forum Authoring (DVD)Replies: 26Last Post: 15th May 2009, 01:38 -
Maximum running time
By biged670 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2009, 17:39 -
DGPulldown and running time?
By ecc in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:23
