I searched the entire forum and guides for OGM to DVD and I did not get the results I was looking for. The closest guide I found for OGM to DVD was actually a OGM to SVCD guide: https://www.videohelp.com/forum/userguides/170944.php
My question is can I follow the same steps in the OGM to SVCD guide and apply it to DVD? If so how do I add 2 audio tracks and 1 subtitle track in TMPGEnc DVD author? Here are the tools I used so far:
Virtualdubmod - use to rip the 2 audio tracks and subtitle track
TMPGEnc Plus 2.5 - use to extract the video
TMPGEnc DVD Author - Here's my last step and my only problem
The further away I get from the things that I care about...
the less I care about how much further away I get... -
I found two guides, the OGM --> SVCD one that you found and another that came under the OGM --> DVD search. This is the link to my search results. Follow the "All --> DVD" guide and you should be OK, otherwise you could try adapting the SVCD guide if you're more comfortable working in that way.
Have a look at this guide. At the sixth picture down, look to the paragraph on the right. TMPGEnc DVD Author only supports one audio track. Unfortunately, you'll either need to do without one track or find a new package that does support more than one track.
Unfortunately, I haven't ever needed to do this, so I can't tell you what's best.
Hope this helps,
Cobra -
I used the same vague search method (didn't limit my search) and those are the same 2 results I got too. If TMPGEnc DVD Author can only do 1 audio I would want that audio to be Japanese but since I'm still not very good at listening to Japanese yet I want the english subtitles that came with the ogm file and thats what I've been trying do all along. Is there another DVD authoring program thats allows me to combine the audio and subtitle file onto a DVD or better yet, allow me to add both audio tracks and subtitle to DVD?
dvdauthorgui, dvdlab pro....click on tools here to left and you can search for dvd author tools with either selectable/several subs or selectable/sevaral audio tracks.
Thanks I'll give those a try.
Need a Program to convert avi/mkv/ogm to dvd that is free for winxp
By animefanx in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 03:22 -
How to Convert OGM!?!
By SamohAD in forum Video ConversionReplies: 6Last Post: 19th Mar 2009, 18:42 -
How to Convert OGM to DVD
By dafreak in forum User guidesReplies: 108Last Post: 17th Feb 2009, 16:59 -
HOW-TO - CONVERT AVI, OGM or MKV to DVD
By Ecko_Blue in forum User guidesReplies: 44Last Post: 19th Sep 2008, 09:10 -
Batch Convert AVI/OGM/MKV to DVD (anime)
By aktee in forum User guidesReplies: 480Last Post: 4th Nov 2007, 18:18
