I just bought a Sony DCR PC109 camera which records on miniDV. I am trying to capture the video in Adobe Premier but I cannot get anything higher than 320x240 resolution. I am transfering with a USB cable. Also, I get the message "The DV Device is unavailable for device control". The capture resolution IS set to 640 x 480. I also tried capturing in Ulead and I had the same problem. Could this be that my drivers aren't up to date? If so, what drivers would I look for? Camera drivers or video card drivers? Could it be that I have to update Premier?
Any help is appreciated.
-Adam Steeves
You'll need firewire to capture full DV resolution. USB 1.x isn't fast enough for 720x480 DV.
See the "USB Streaming" details at this site:
http://www.crutchfield.com/S-ckckV2NqYLY/cgi-bin/ProdView.asp?a=&s=0&cc=01&g=53700&id=...o&i=158DCRP109
videocast osprey capture resolution
By jaybird in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2009, 22:29 -
DVD resolution problems / confusion
By Laurels in forum MacReplies: 2Last Post: 5th Jun 2008, 03:57 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 01:16 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 11:57 -
capture resolution
By stompinne in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2007, 14:45
