Came to use this program again today after a few weeks of not needing it..splash screen comes up, but the program doesn't start..I've made no alterations to my installation since I last used it, so is this something being done by the program writers again?
No. There may have been a change to your system. If you double click on the SVCD2DVD demo.exe file in the SVCD2DVD folder you can redo the registration process. This should solve the problem.so is this something being done by the program writers again?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Originally Posted by ChrissyBoy
Solved mine.. It happened again for some reason, but this fixed it..
Brill
Rip subtitles - won´t work.....help
By manutd in forum SubtitleReplies: 2Last Post: 9th Nov 2008, 17:24 -
conversion programs just won't work!
By Sean O'Scare in forum Video ConversionReplies: 19Last Post: 17th Feb 2008, 02:58 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
