hello
i'm converting my old vhs tapes to dvd, and the dvd's looks fine on my computer but on my tv seems a bit jumpy, or something. i don't know very well but something it's strange on the video.
what can be wrong?
what i'm doing is:
-capture from vhs to avi with a canopus advc 1394 (i don't lost any frame during this process)
-then with avisynth i framserve to cce and encode.
-then i author with dvd-lab.
i'm not deinterlacing the video, can be this that cause this jumpy when i watch in a tv??
on my computer it's fine. i used force bob and auto on windvd just to see if the problem could be the deinterlace and i didn't get any conclusion.
I guess the tv's deinterlace the videos, am i wrong? cause i don't see the lines on any of my tv's.. but both have that weird jumpy effect.. :/
any advices to help me out?
Might be using the wrong Field Order. That can make action and pan shots jump.
I did a short clip test where I encoded two identical video clips and put them on a RW dvd. One in Field A and the other in Field B, and played them on my TV. I found that my setup required Field A. Might be a good idea to do this simple test yourself. Then you'll know for sure.
Good luck. -
you encode with cce or tmpeg? or other program? i'm using cce and i don't find that option, only on tmpeg.. do you think that cce can have the same option but with other name?
The FIELD setting for newer versions of CCE is under the VIDEO button in newer versions. It's called 'Offset Line'. Try chaning it from 0 to 1.
Impossible to see the future is. The Dark Side clouds everything...
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 14:07 -
Video DVD that doesnt play audio on DVDplayer but plays fine on computer ?
By hiavi in forum Video ConversionReplies: 6Last Post: 15th Jan 2009, 14:01 -
DVD Plays fine on computer but is screwed up on standalones
By jalopy6 in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 08:17 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 18:26 -
Authored DVD with GFD, fine on TV, no menus when playing on computer.
By towtruck in forum Authoring (DVD)Replies: 6Last Post: 8th Jun 2007, 17:40
