is it possible to convert 4 avi to dvd.
any help appreciated
Results 1 to 12 of 12
No it's not. 1,2 or 3 is fine but Windows will not let you convert 4 AVI's.
kauser, you need to give us a lot more information before your question can be answered. Filling out your computer profile helps also. There are many different types of AVI, which one are you asking about? Gspot or AVIcodec will tell you what you have. How long are all the AVI's combined? Simple answer is you can fit about 2 hours on a DVD, more or less, depending on how you encode it to MPG.
The simple answer to the simple question is yes. But there are other factors which would either suggest no or you would not wish to.
So the avi's are Xvid.Originally Posted by kauser
kauser - the people on this site can help you , but we need as much information as you can give to be able to help you with your problem. -
From the 'Convert' section to the left, Xvid to DVD: https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=XviD+to+DVD&...or+List+Guides Somehow I knew they were going to be Xvid. Now the answer is maybe you can put 3 or 4 on a DVD. Xvid is highly compressed. When you recode them to MPG, they will probably get much bigger.
I think you need to lose yourself in the guides section, and fast. There are a number of guides that step you through Converting AVI to DVD. FOllow the link redwudz provided.
Next time make sure you have a look through the guides section, because most elementary answers are contained there.If in doubt, Google it.
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Convert my dvd's to Avi
By drgt in forum Newbie / General discussionsReplies: 52Last Post: 3rd Dec 2010, 05:28 -
convert DVD to AVI...?
By snadge in forum DVD RippingReplies: 5Last Post: 9th Aug 2009, 21:07 -
Convert DVD to DV AVI
By bgmagic in forum DVD RippingReplies: 14Last Post: 4th Feb 2008, 13:55 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
