I have these two .BIN and .CUE files and ussualy burn at 16 to 24x. When I try to open them on CD, they wont read or some parts are corrupt.. Now Is Nero causing this? (I am burning with Nero using the "burn image" option)
Does anyone have any other programs that can facilitate burning images correctly?
Note: they are only .BIN and .Cue files, no ccd nor .IMG....
Next Generation Classic......
I doubt it's Nero. One of the things it does well is image burn. I used to do all my SVCD Bin/Cue files with it, usually at 40X. You could try DVDdecrypter to burn image files. If that still doesn't work, it's probably media or file problems.
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 12:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 13th Apr 2010, 23:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 12:51 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 15:55 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 19:53
