I went to the link in this site on how to convert from vcd,but I can't find any of the files that the tutorial mentioned.
How can I convert this 2 cd's which are in vcd,into mpg so I can play it in a vhs?
thanks.
Rigo.F
I think you may need to rephrase you question into something that makes sense.
vcd IS mpeg -
If what you want to do is record a vcd to VHS tape, put the VCD in and then just hook your VCR to the composite output of your player or computer, along with sound out and hit record.
Originally Posted by Rigo
well,so why people convert all the time dvd's to mpg files? dvd is mpg too..
What I need is convert this vcd into mpg and using a hardware I can play the mpg in my PC and send the signal into a vcr and record into a vhs tape.
I think the question makes sense,because if you play the vcd movie you can't send the signal into de VCR because is using a software to reproduce the signal,but if you play a mpg file using a hardware,then you send the signal with the capture card into the VCR.Rigo.F -
Playing the mpg alone doesnt get played by hardware,it gets played by windows media player or any other s/w,just output the video and audio to your vhs when playing by whatever s/w you want such as windvd or powerdvd or even navigate to your vcd and open the dat file with windows media player.Dvd isnt just mpg2,its several media streams including mpg2 in a vob container.
well,that what my video capture do,the thing is that I don't know how to convert the vcd movie into something that my capture card can process,and that is mpg,yes,in the computer also I can play the mpg file with WMP
But, I will try it to connect the stabdalone dvd player(which can read vcd's) into my VCR and Record.
thanksRigo.F -
I didn't had any idea that I could record direct from the standalone dvd player to the tv/vcr combo,so now when I dont feel that I want to use another dvd+r or dvd-r for a movie,I will just use a VHS tape.
thanks.Rigo.F
Replace about 50 frames of video in an .mpg file (keep audio the same)?
By gastrof in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2011, 22:29 -
Ho to remove hum from a video mpg file?
By perfection in forum RestorationReplies: 3Last Post: 24th Nov 2007, 09:02 -
MPG File to VHS Tape?
By Coxjeet in forum CapturingReplies: 2Last Post: 6th Sep 2007, 03:12 -
Trying to burn a mpg video file to DVD
By bhxtyrant in forum Authoring (DVD)Replies: 8Last Post: 11th May 2007, 14:22 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
