  1. Does anyone know how to burn VCD's on a Mac?
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    I do but you shoudl post in the Mac Forum.
    Any way...
    if its standard .bin/.cue all you need to do is launch Toast 6, click COPY, choose .bin/.cue and select the .cue you want to burn
    if you want to use something free, use Missing Media Burner, or FirestarterFX [both avaliable for free on versiontracker.com]
    if you have a .mpeg file you will need to first put it in a .bin/.cue which you can easily do with VCDToolsX and then just follow the burning steps as described above
  3. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    And if you have a QuickTime-playable video file that's not MPG or VCD format, you can use Toast 6 to convert it for you, by selecting Video mode, then choosing 'VideoCD' on the left side column, and then dragging your QT-playable files onto Toast's main window, and hitting 'Record'.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  4. Member galactica's Avatar
    Jan 2003
    agreed
    it just all depnds on what he/she has as a starting source
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    don't forget if you have Mpeg-1 files already formatted,
    you can use VCD Builder 1.1, drag and drop your
    MPEG-1 to the menu window, and click burn,
    in which case it would hand it off to Toast 6, Dragon Burn,
    or Discburner to burn to CD.
