Hi everyone !
I got a problem when I was trying to open a mpg file ( VCD ) using the TMPGEnc , when I browse to the file I want to convert , an error message appears, the following : File "C:\[File Location]" Can not open, or unsupported
Why this happens ? I remember that I used this programm before and I opened a VCD file withought any problem ... Any Idea please ?
I'll be thankfull for any help .
Best Wishes !
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Thanks for your answer ...
I looked in the URL you gave me , then I installed MPEG2 Plugin but it didn't help .
The file I want to open is mpg a VCD file not SVCD ... I hope there is possibility to open such files in that programm to convert it to anything else ..
Thanks for any help ! -
The link I gave says to adjust the directshow priority of the environmental settings. Did you do that?
Hello. -
Originally Posted by Tommyknocker
I think DirectShow is usefull for AVI files ... But I did what you said , no luck .. isn't it possible to open the VCD ( mpg1 ) files in this programm to convert it ?
The programm I use is ver. Plus 2.521.58.169
Any help please ?? -
Anyone just answers me is it possible to open VCD ( mpg ) file in TMPGen to convet it to other Format ?
Is it just possible or not ?
Thanks ! -
Yes, TMPGEnc should be able to read mpg1. The question is - why would you want to reencode a VCD spec mpg? It's bad enough already!
/Mats
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
