i just bought a Fisher FVD-C1 that records in MPEG-4, and i tried to convert that to a 702x480 AVI file using TMPEnc. but there's a big sync problem (the sound ran ahead of the video by a wide margin). can someone help me out? thx.
I don't think this is an advanced conversion question. I believe this should have been posted in the newbie/general questions.
However,
MPEG-4 video is stored in AVI format. And Tmpgenc is not the ideal tool for working to convert or resize AVI files.
Are you trying to resize the source video? If so, your tool of choice should be VirtualDUB.
What codec are you planning to use for the new video? If you want to keep it, you would probably choose a high compression high quality modern codec, like xVid or DivX, both of which are MPEG-4.
Your audio/video sync loss is probably due to the wrong frame rate selected. Video seems to run slower than audio. As you mention a resolution of nnn X 480, I guess you want NTSC format, so your source video might be captured at 29,97 fps and perhaps Tmpgenc is set to process at 25 fps.The more I learn, the more I come to realize how little it is I know.
HDV .m2t footage - Best quality conversion to MPEG4- method/tools
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 01:30 -
MPEG4 to AVI
By Jomapil in forum Video ConversionReplies: 2Last Post: 12th Apr 2012, 10:52 -
MPEG4 to AVI
By Jomapil in forum Video ConversionReplies: 2Last Post: 30th Mar 2012, 15:55 -
MPEG2 to MPEG4 conversion
By altavistasf in forum EditingReplies: 2Last Post: 11th Jun 2010, 23:35 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 16:56
