Hi -
Using Adobe Premier 6.0
1. Some images are shaped like the Television screen (slightly wider than taller) and fit just fine.
2. Some images are vertically oriented, and have some black space on both sides.
3. When "Maintain Aspect" is not selected, and "Lock aspect ratio" is not selected, the result is: Vertically oriented images that don't fit the width of the screen get stretched to the width of the screen, abnormally.
4. When "Maintain Aspect" is selected, and "Lock aspect ratio" is selected, the result is: A frustrating black bar of pointless black space on each side of all images, resulting in slightly slimmer wide photos, and slightly slimmer vertically oriented photos too.
5. My goal? To have the vertically oriented photos maintain their aspect ratio and the wide ones as well, without those annoying black sidebars.
Note: Im aware of two locations for this aspect ratio setting.
a) Edit, Preferences, General and Still Image, Lock Aspect.
b) Right clicking on the image in the timeline, going to Video Options, and Maintain Aspect Ratio.
My assumption is they are one in the same setting. If they are not, please let me know.
HLT
HLT
Lock Aspect is used to set Maintain Aspect Ratio default at Premier start up.
One problem I had using Premier6.0 was not maintaining aspect ratio to strech vertically. After rendering the Time Line, those stills would come out black. Problem was solved in Premier 6.5.
Chas -
The simple solution would be to crop all images to 720 x 540 or 720 x 534(NTSC). Once they are croped to the correct size, import them into Premiere. That way all images will display correctly.
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 02:53 -
DVD to PSP - Aspect ratio / black bars / squashed images
By mtdg in forum DVD RippingReplies: 3Last Post: 2nd Nov 2008, 15:56 -
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 02:43 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:27
