Hi
i am trying to convert an avi movie onto dvd by using canopus procoder.
i loaded the avi into canopus and it told me it was going to take 8 hours to convert..when i got back to it today..the converted file was 8gb..too big for dvd.
does anyone know how i solve this problem ?
Wingman.
did you choose dvd?
did you check under advanced settings so the size was set to dvd-r/w?
is your source a divx or xvid with mp3 audio?
I'm currently testing procoder express, it is very easy to use and it can author also. I will maybe make a basic guide for it. One strange thing is that the default dvd size is set to 4700 MB. -
I predict a sizable influx of Procoder Express users.Originally Posted by Baldrick
i did not set the size to dvd-r/w why dont i need to set that to dvd-r then..why dvd-r/w ?
this is what i have selected on each page of procoder...
when i am going through the procoder..i dident use the "set in point" or "set out point" not sure what it's for yet..only had this program yesterday.
i did not use the cropping tool either.
the source is xvid with ac3.
i used the option.."use wizard to select a target"
selected DVD
the middle option..MPEG2 program stream (m2p)
then constante bitrate CBR
and set the time to 90 mins.
are these settings correct?
Wingman.
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 05:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
What happened to Procoder Express?
By lordsmurf in forum Newbie / General discussionsReplies: 11Last Post: 25th Feb 2008, 23:54 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
