I have 2 PC card slots...I never knew what these were meant for, or if I could use them for anything interesting....any ideas!??
Results 1 to 12 of 12
Smile
Smile -
Are you talking about PCI slots? About 3-4" long, take internal expansion cards.
If so, how about a digital TV card? You could save the MPEG-2 stream directly to your hard drive and burn it to DVD for watching later. I want one of those, but I don't have the money.
Cobra -
maybe you mean pcmcia slots? how about a wireless network card, external hard drive or compact flash adaptor?
I think thats it...came with 2 slots....not sure what I can do to make use of them.Originally Posted by CobraSmile
Smile -
This is the PC...the front where I marked in red opens to reveal usb ports, a headphone input...and the PC card slots...not like the one you have circled...I guess
THis pictures shows the specs...in JAPANESE...simply translated it says PC Card Slot Type blah blah...anyway, can someone tell me what these do!?
Smile
Smile -
More likely PCMCIA slots... never have seen an external PCI slotOriginally Posted by beavereater
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
PCMCIA Card Slots.
Type I cards are RAM and/or ROM cards,
Type II cards are for things like modems and NICs, but you can also find 5GB hard drives in this configuration also. Type II cards may take up the entire PCMCIA bay even though they only plug into one slot.
Type III cards are big enough for larger hard drives, but they take up both slots (at least the ones I've seen do).
One of the slots is likely a CardBUS slot, a 32-bit, high-speed port that you could use for a PCMCIA video capture device.
They're also used as 'keys' to allow access to your computer. You carry your card with you, and the card plus a password combination allows you access to a given computer. -
Just for reference, "PC Card" is the new name for "PCMCIA". PCMCIA is too hard for us dumb consumers to read or say, so the industry decided to rename them.
A man without a woman is like a statue without pigeons. -
sounds logical. coming soon, the Camera Card. CF? SD? MMC? MS? NO! Camera Card. yes, but.........
Don't forget MD. Why does everybody forget MD?Originally Posted by flaninacupboard
(IBM MicroDrive. 2.2GB drive that is about 3½ cm x 3½ cm. It's also known as the Postage Stamp Hard Drive...) -
because the MD's i've seen have been in CF format, so the same thing really.
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
Do I have the right slots for the Avertv HD DVR?
By MichaelEatsWaffles in forum Capturing and VCRReplies: 2Last Post: 11th May 2010, 23:42 -
PCI E Slots question.
By A Traveller in forum ComputerReplies: 13Last Post: 9th Oct 2009, 12:05 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
PCI slots are starting to act up due to one faulty AGP video card ?
By MidnightMike in forum ComputerReplies: 9Last Post: 8th Nov 2008, 17:05
