Since version 0.0.9f (now using g) I get the following error message at the beginning of a DivX->KSVCD process:
Encoding started on Sat May 8 11:33:10 CEST 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
2004-05-08 11:33:11.225 movtoy4m[816] CFLog (21): Error loading /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType (No such file or directory, errno = 2)
INFO: [yuvscaler] input: frame size: 352x576 pixels (304128 bytes)
INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 352x576, take 352x576+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 352x576, 352x576 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 25.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 352x576 pixels (304128 bytes)
INFO: [yuvscaler] output: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
Allthough it doesn´t seem to affect the encoding process I wanted to tell you about it.
beige G3 w/OWC G4@500
80GB/512MB
10.3.3
BTW - your app simply kicks a**!!! The swiss army knife for video encoding.
caozinho
Rip different
OK, it seems nobody does know anything about it, or simply nobody ist interested in answering.
It seems, that the above problem causes a system crash after about 35% of the video encoding process. The same stream encoded with the mpeg2enc settings works.
My G4 TiBook doesn´t show this error and the encoding process runs through flawlessly.
Any suggestions major?Rip different
Error message! Help!
By XAPHSNYC in forum MacReplies: 6Last Post: 8th Feb 2010, 14:05 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
yuvscaler PPC ?
By ResEdit in forum ffmpegX general discussionReplies: 5Last Post: 28th Jan 2008, 13:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
