I got an error: "Chunk size extends outside of parent" when I open a multi-part AVI. What is this error? And how to solve it?
My box:
K6-2+ 500 MHz
EPoX MVP3C2 (VIA MVP3 Chip)
192MB SDRAM
Matrox Marvel G400-TV
Main HDD: WD WW600BB, hooked on a promise Ultra 100 -
what ver of virtualdub are you using? what is the size of your capture segments?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I'm using VirtualDub V.1.4.7, and the size of the segment is 1900 MB, but that capture seemed have caused this feature of VD to be failed... I got a 3.15 GB segment. -
that sounds abnormal. how many drives/partitions are you capturing to? is the priority of all drives set to 0? btw, virtualdub 1.4d & up will properly accept open dml segments larger than 2gb
After trying with other applications, I found that TMPGEnc can read both segments (The first one is normal and the second one is the abnormal one I've mentioned), but "normal" applications (e.g. MedioStudio 5.2 or Matrox's PC-VCR) cannot open either.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 16:59 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 11:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
