hello, i am trying to add effects,subtitles,titles,etc. to a home movie i captured,its already Mpeg2 format,all i want to do is spruce it up some,what program can i use to do this,i was using nerovision but it keeps crashing? its a shame after spending hours on something ,to only bam...!@#$#@!, its only 2.1gig movie(1hour 10min.+/-),i used virtualdub(huffy) to capture,then TMPGEnc to encode it,i know how to make the dvd,all i need is a decent program to add things like mentioed above"freeware" if possible,thanx.![]()
Freeware? Thats's hard. But TMPGEnc DVD Author can do most of what you want. Effects and subtitles, I believe, are added before authoring. For freeware, check the 'Author' column to the left.
Whas is the Easiest to Use DVD Ripping Program?
By Gatimo in forum DVD RippingReplies: 4Last Post: 13th Jan 2010, 21:23 -
Easiest Cutting Program?
By Merkaba188 in forum EditingReplies: 9Last Post: 4th Nov 2009, 21:25 -
Easiest Program To Merge Two DVDs Without Interruption
By V Bot in forum DVD RippingReplies: 7Last Post: 11th Sep 2009, 21:27 -
What is the easiest program to convert MKV to AVI (without audio)
By Mylo in forum Video ConversionReplies: 2Last Post: 22nd May 2009, 16:52 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 04:10
