Hi there...
I followed the vcdhelp pages for both capturing and converting but have a cpl of problems and really need a little help here...
I've done a VHS->DV Cam->Firewire Capture of my Spiderman Venom Saga Tape with Adobe Premiere;
using the DV NTSC Standard 48Khz Preset:
Video Settings:
-Standard NTSC Video (4:3 Interlaced)
-DropFrame Timecode Numbering
-Pixel Aspect Ratio D1/DV/ NTSC (0.9)
-Depth: Millions Quality: 100%
Audio Settings:
-48Khz (16bit) Audio
-Compressor: Uncompressed
which gave me the following (sweet!) results:
-720X480 (0.900)
-00;57;12;14, 29.97 fps
-48000 Hz - 16bit Stereo (192kbps)
-Avg Data Rate 3.61MB per second
from which point i used TMPGEnc to convert the AVI to SVCD-NTSC using the default codecs & settings while following the VCDhelp SVCD convert help page:
-Super Video-CD NTSC (default)
-MPEG-2 480x480 29.97fps (default) CBR 2520kbps
-Layer2 44100 Khz 224kbps (default)
1st problem:
the output quality from the original (12+gig original capture) to a (1.1+gig SVCD MPEG) is pretty good and all but the vcdhelp.com comparison page states that SVCD resolutions are 720x480 720x576 (or lower) but why do i end up with a 480X480 from a 720X480? And is there any way i can get the full or as close to full resolution as possible? (and will it still be playable (fullscreen) in an SVCD Compatible DVD player?) (and I don't mind splitting to two disks) either way..i'd like to keep the end result (burn to cd) as close to the best possible quality/resolution as possible).
2nd problem:
I'd also like to convert the original (12+gig DV-AVI) to DivX (still don't mind splitting to two disks) and compare the two (SVCD to DivX) to decide on which one to keep as a final backup (burn). The problem is is that i want to Divx (encode) the original capture file but VirtualDub won't recognize it. Anyone know of a workaround? (aside from Divx'ing the SVCD which may result in a much worse encoding than encoding the orginal no?)
And I repeate Yes i followed all vcdhelp pages
Ack! Help please!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Well, SVCD is 480*480 (NTSC) or 480*576 (PAL). Any SVCD-Player will show that fullsize on your screen. Horizontal resolution is 2/3 of a DVD. If you want 720*480, you have to encode as X-SVCD.
2nd problem:
No real problem there. Virtualdub annot read the DV-stream-avis. Just goto http//www.mainconcept.com and get the DV-codec (demo-version will playback without problems but will add a watermark when encoding to DV) from them. Then virtualdub will recognize the DV-avis.
ahah! thankyou omoses thankyou very much!!
K quick question regarding the 'demo' codec (from mainconcept.com) will that effect any future DV encoding with adobe premiere at all or will it be a distinguishable codec that i can select or de-select by (distinguishable) name? And do you have any idea why are they trying to sell us their codec in the first place? Any other reasons (other than solving my particular problem) that you might know of?
"All good things in life should be free"
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 06:15 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
How to convert Digital Cam AVI to Xvid or Divx?
By Newbie_here in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 01:48
