I recently bought a 50 pack of CD sleeve pages from RIMA.com:
http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=6128&Category_Code=A
They need an "oversized" binder to contain them. Since then, I have looked for this size binder all over and have yet to find it. I have been to Staples, Best Buy, Rite Aid, and other stores with stationery. These oversized binders are so hard to find apparently. Anybody can point me in the right direction?
I noticed this when I looked at your item:
Binder holes line up with any standard 3 ring binder( spacing 4 1/4" center to center)
Width of pages will extend beyond standard binder, requiring 'oversized' binder to fully contain themHello. -
Since the last post, I have been to every imaginable local store that carries binders or CD wallets; Best Buy, Office Depot, J&R and many more.
I ordered RIMA's special oversized binder when they came out:
http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=6305&C...gory_Code=CDBD
These are not terrible but I don't like them too much. They have weak rings that gap and a stupid carrying handle on the back that prevents you from laying the thing flat. I would try to return it if not for that fact shipping it would probably cost as much as the binder and also the hassle.
I have found myself using my "undersized" Staples binder more and more because they are easier. If only they were a few inches wider!
Has anyone been able to find oversized BINDERS. Not special CD wallets or the like. Just regular for-paper binders that are a few inches wider. These would be ideal as long as the rings are not too large. -
I have the RIMA sleeves too, in a standard binder from Sams Club. Many people have complained about how they stick out. I don't find it too annoying, but here's the solution I came up with and ordered yesterday. Damn cheap online for what it is. Not the best in it's field but better than a binder.
Best of Luck finding a binder that works. If you do, please report back.
Thanks,
-Evan- -
Even your solution doesn't work for me because I need them to be portable.
And I REALLY, REALLY like the RIMA sleeves. They are the best I have ever used and I have practically ordered myself a lifetime supply. I just can't believe there are no large square binders out there. -
I am not sure of their binder sizes but you might want to have a look at www.univenture.com
No, I'm from Iowa. I only work in outer space.
Are plastic sleeves good for DVds?
By cynikalhedonist in forum MediaReplies: 10Last Post: 28th Feb 2011, 01:12 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 20:39 -
DVD plastic sleeves
By danielmak in forum MediaReplies: 2Last Post: 8th Mar 2010, 03:51 -
any sleeves better than tyvek?
By spiffy in forum MediaReplies: 3Last Post: 20th Aug 2007, 12:15 -
Quality inserts/sleeves for Amaray cases needed
By boing in forum Newbie / General discussionsReplies: 1Last Post: 9th May 2007, 08:24
