Does any one know of a way to capture a TIMED 1 hour clip using Vegas 5 and an ADVC-100? When I use the advanced record and put a time in, it wants to control a video device (such as a Digital Camcorder). If I can't, I'll revert back to using MF2 for the captures.
3.141592653589793238462643383279502884197169399375 105820974944
I presume you leave your machine alone, judging by the fact you want to time it to record.
In this case, you could set it up ready to capture and, before pressing the final button to capture, leave it there and use macro software with a timed trigger to press the button at the preset time for you. A clunky solution, I know but it might work until you find a more elegant one. -
why not use Scenalyzer to do schedule captures? you can time record your captures using Scenalyzer.
http://scenalyzer.com/main.html -
Scenalyzer sounds like a lot better way to do it ..
If it's anything like Vegas 4, then it should have something in the video capture menus.
Go to Options, Preferences, and Video and there hopefully should be something for Timed video capture.
OOPS, Make that in the Vegas Capture Program, Options, Preferences, Capture, not Advanced Capture. Hopefully it's not too different from 4."*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda -
Thanks for the suggestions. Yes, I leave it alone for long periods (watch TV, go to dinner, cut the grass, etc.). I've got a lot of movies and old laser karaoke disks that I've been SLOWLY transferring to DVD. The Scenalyzer looks good, but, if I have to use a second program I might as well use MF2 since I already own it.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
