I used vobblanker to remove some extras from a DVD. When I try to open up to files in DVD shrink, it says cannot decrypt VOBS or invalid filename. Can anybody lend some help?
Results 1 to 9 of 9
Try just using DVDShrink for the process. The whole purpose of DVDShrink is to allow the user to pick and choose what content they put on their DVD-R, so VOBBlanker is really an unnecessary step.
Yeah, I was just going to use DVD shrink, but I wanted some extras and to keep a menu.
You're probably going to have to make your own menu in order to do that (I have no idea how menus work, however).
just uncheck the boxes of the files you want to remove. When transcoded, it will leave those files out.Originally Posted by kmac14_99
The VOB files that are only 1 mb are able to be added, but when i try to add the main files to DVD shrink, it wont let me.
it automatically backs up all files unless you tell it not too if you are using 3.0 or higher. What are you trying to add? Just do full backup.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
VobBlanker substituir o menu/How to replace DVD menus with VobBlanker
By escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 02:52 -
Different DVD file structure? VobBlanker error: Cell Not Found
By siebenbuerger in forum Authoring (DVD)Replies: 3Last Post: 16th Dec 2010, 12:13 -
Can't find still in dvd with pgcedit or vobblanker
By CuriousYellow in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2009, 02:56 -
DVD-RB does not recognized files after VOBblanker
By shreeit in forum DVD RippingReplies: 0Last Post: 6th Aug 2007, 11:10
