Results 1 to 10 of 10
    May 2004
    Australia
    This happens ever so often but when it does its something i really need or have to do.
    I am trying to copy a dvdR to another dvdr ... as i said this doesnt happen all the time.
    Firtly i try and do a copy disc burn (which always usually works) I get an error saying underflow
    So i goto rip the files, using shrink first, comes up with a redundancy error failed to read drive :
    I then swapo dvd drives this sometimes fixes the problem but sometimes doesnt as in case im talking about, same error.
    I am currently trying decrypter but i feel this will fail also.
    I know other people have this slight problem im just wondering ifanyone knows whats causing this? As i said its from DVDR to DVDR
    Confused
  2. Banned
    Jan 2004
    Going in Circles
    copy to the hard drive first
  3. gitreel: What is the format of the files created on custom DVD-/+R's? Are they .VOB's? Can you just copy them from disc to disc to make a copy?
    Compatibility issues have prevented my DVD-ROM from being able to read any kind of custom burned DVD disc.
    May 2004
    Australia
    yeah they are, its a burnt dvd r then i try and copy that dvd r and it fails
    just tried with dvd decrypter and got this message
    W 10:29:52 Failed to read Sector 2170576 - L-EC Uncorrectable Error
    sdo no program seems able to decrypt or copy this disc which is a regular dvd that plays well
  5. Banned
    Jan 2004
    Going in Circles
    vob, ifo, and bup. The disks are usually encrypted. They have to be decrypted first. If they are double layer, the movie either needs to be transcoded or split. Sometimes you are dealing with disc images, in which the method is different.
  6. Banned
    Jan 2004
    Going in Circles
    .vob is video object, .ifo is information, and .bup is backup
    May 2004
    Australia
    no no ... its a single layer disc im simply trying to make another copy.
    Stated i cant burn disc to disc
    and i cant copy to hard drive
    this error message comes up
    when this happens its usually right at the end, like in this situation
  8. Banned
    Jan 2004
    Going in Circles
    try cleaning the disc
    May 2004
    Australia
    the disc is new, and yeah its clean thats not the problem. Its like sometimes burnt dvdr's have an unreadable file on them 5 programs all failing in exactly the same place
  10. Banned
    Jan 2004
    Going in Circles
    tell decrypter to ignore mastering errors
