I've posted this in the DVD to AVI forum, but didn't get much feedback.
LINK
Basically, I'm new to Divx/Xvid encoding, and want to be able to get high quality backups of my DVDs so they can be played on my new Philips 642 player.
So far, I've encoded a few Band of Brothers episodes to Xvid (1 hour long, 700mb file size). I used AutoGK to do it, and the resolutions varied from 544x304, 576x320, to 608x336.
Initally playback on the 642 wasn't what I was expecting. While it wasn't bad, the image looked stretched or pixelated.
Since then, I've backup LOTR1 (3 hours long, 1500mb file size) to a DVD-R using a resolution of 640x464. It looks better than BOB, yet the bitrate is smaller. The resolution is higher, though.
I really only care about playback with the standalone player. Is it better to always go with the higher resolutions like 640x480, or even 720x480, even with a lower bitrate?
Also, the LOTR backup was fullscreen (4:3 AR), while BOB was 16:9 (anamorphic). Is there a problem with anamorphic resolutions on the standalone Divx players?
Thanks!
Closed Thread
stretched... caused by aspect ratio differences between PC and TV
pixellated.. generally lack of bitrate / other.
Try Fairuse and use hyper-quality & TV aspect ratio ..this might solve one or both of your problems
BOB is v.v.v. hard to compress, so I am led to believe, because its got Tom Hanks in it.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
AutoGK does not allow you to set the vertical height and in my expierence it always selects a height that stretches the image. Try Vidomi which let's you set both height and width. I just did some Farscape episodes with it. season four is 16:9 like B.O.B. Use a resolution of 640x352,works on my DVP642.
Thanks for the advice, guys.
So far, I'm impressed with both the quality and output of the LOTR1 backup using the 640x480 and 512x384 resolution.
My bitrate is well above 1000, so I don't figure that's a problem.
I'll give Dr Divx a try and see how that goes.
Using Dr. Divx, I see it recommends a resolution of 720x400 when I start to backup BOB. It seems as though I read somewhere that standalone players like the 642 don't work with resolutions over 640? Is that true?
Can philips dvp 3588 dvd player,play a divx file of 720p resolution?
By jazzymegatron in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Jul 2010, 10:06 -
best standalone DivX player?
By coyote2 in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2008, 11:48 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16
