Hi,
I read here that to convert back from svcd to mpeg, all
you have to do is copy .mpg file from the cd to the hard
drive. I would like to be able to capture some video,
convert it to svcd and if I need to re-edit it for some reason, just get it back that way, but when I try this, I can't open it in media player or edit it with my editor software (Dazzle MovieStar). I hope I don't have to burn the original mpeg to a cd if I ever decide I want to re-edit it again, do I??? It seems in the process of converting it to svcd, something must get added to the original mpeg-2 file. Is there a utility that can un-do that process???
Thanks in advance. Learned a lot from this forum, thanks
to everyone!!!
-Dennis
You may utilize VCDGEAR software (freeware).
Get it in this website:
Go to "OTHER" (you can see in the side left column on this page)and click => "TOOLS" and you'll find VCDGEAR in CONVERTERS/REPAIR item.
Running the soft you choose "dat to mpg" converter and you'1l save it in blahblah.mpg file. It's easy.
IMPORTANTE: REALLY, I DON'T KNOW IF VCDGEAR CONVERTS TO MPG2(SVCD). FOR MPG1(VCD)IT WORKS PRETTY FINE.
ANYBODY CAN HELP dennis290 IN THIS? Tks.
Anyway, you may test it.
Bye.
H.264 mpeg-4 problems playing back
By jedis in forum Video ConversionReplies: 2Last Post: 23rd Mar 2011, 23:00 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
ripping a avi/mpeg back onto computer
By pw29010 in forum DVD RippingReplies: 2Last Post: 16th Feb 2009, 16:34 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
Back up and converting
By Gustav Klimt in forum MacReplies: 2Last Post: 25th Jun 2007, 15:17
