50-Pack Philips 4.7GB DVD+R Discs $30 Shipped
OfficeDepot.com has two packs of the Philips 4.7GB DVD+R 25-Pack for $80 - buy one get one free coupon code "29572940" (Expires 5/8) - $10 off $30 coupon code "30332206" (Expires 5/22) = $30 with free shipping.
Don't know whether 2.4x or 4x. in stock now in CA. just placed order. anyone know the media ID for this dvd+r (and speed too)?
Results 1 to 13 of 13
I would guess 2.4x
See this forum for some discussion.
http://www.slickdeals.net/forums/showthread.php?threadid=22589&postid=241632#post241632 -
@mrinalkarOriginally Posted by mrinalkar
These Philip DVD+Rs are labeled as 4x. I have the Plextor 708A DVD burner and this media has burned at 8x without any failure or coasters. I've been using these Philips for six months now. These are the RICOHJPNR01
I learned of this deal last night and ordered 6 (+6 free). You will need to place multiple orders in order to use the coupon code mulitple times. Using both coupons make this an exceptional value! -
Originally Posted by noki
These Philip DVD+Rs are labeled as 4x. They are the RICOHJPNR01. They burn at 8x without incident, using my Plextor 708A. This is, IMHO, a certified "steal of the day!" -
apparently you also need multiple accounts. just tried to place 2nd order, but site said I already used the coupons. now to set up another account or two...You will need to place multiple orders in order to use the coupon code mulitple times.
authoring? i don't think so. try post in the correct forum. please.
Great deal. Just placed an order. Thanks for the info!
I've used about 20 of the RICOHJPNR01 before and I think they are excellent. -
OPPS...sorry. got carried away with the great deal...wanted to get the word out ASAP before they run out. again my apologizes.authoring? i don't think so. try post in the correct forum. please.
DO NOT sign in as a registered user. As you found out, using the coupon multiple times won't work when you sign-in as a registered user.Originally Posted by noki
When placing your order, do as as an 'unregistered' user. Hence, do not opt for the 'user name/password' account setup once the order is placed. Simply use a different 'first name' for each subsequent order.
I used all different 'first' names, but I used the same credit card and the same email address. The order went through like a charm!
I received email confirmations for all 6 orders! -
westlaw, you're the person of the hourDO NOT sign in as a registered user. As you found out, using the coupon multiple times won't work when you sign-in as a registered user.
your suggestion worked
many thanks. now, to find a way to make more money to pay for all this media....
NOT the ones OD sent me. they are labeled on the spindle cardboard ring as 1-2.4x. DARN IT. ordered 100 total. guess it will be okay if they are Ricoh dye though, even if they are 2x media.These Philip DVD+Rs are labeled as 4x. They are the RICOHJPNR01.
NOTE: just read a thread on another forum and apparently the dye is CMC
. oh well, maybe CMC has improved (4x Memorex, both DVD+R and DVD-R are also now CMC instead of Ricoh).
Where could I find a similar deal for Australian customers?
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Problems with Philips +R DL discs
By carlmart in forum MediaReplies: 17Last Post: 29th Sep 2010, 08:24 -
Philips DVP642 having trouble with X16 discs
By CaspianCanuck in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Aug 2007, 09:49 -
Philips DVP5960/37 Won't Read Discs
By synchro505 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 02:57 -
Philips 20X SPD2413BD won't read 8cm DVD-R discs
By nlec in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Jun 2007, 12:03
