  1. Hi,
    Which program/s besides MenuEdit can I use to edit /not to create/ the menu of an original DVD /backup/.
    Thanks!
    May 2001
    Use SUBRIP to extract the SUBPICTURES, then use PHOTOSHOP to edit what needs to be edited.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  3. Actually I need to insert couple of buttons in the original menu.
  4. Actually I need to insert couple of buttons in the original menu.
    might have to go to hollywood for that
  5. Try Menuedit or DVDRemake
    check the guides first.
