I've been doin dvd to vcd's for a while and had no problem....I have a full version of tmpeg and want to make svcd's....everything goes good until i try to open the 'd2v' file and it says "cannot open, or unsupported". I got it to open once and encoded it but the sound cut out after 1min...I figured out why...cause i didn't have enough space on my hard drive....Iall I need to figure out is to open the d2v file....m getting really frustrated....I already tried to change the envrinmental settings and still doesn't work. HELP PLEASE!
tnx advance!
MooK
heres my environment:
I did a quick forum search and I have found a possible solution to your problem. Try putting DVD2AVI into your TMPGEnc directory:
https://www.videohelp.com/forum/viewtopic.php?t=208732&highlight=d2v+unsupported
I ran a search on all forums for "d2v unsupported". Give it a shot and try a few of the things suggested in threads - it could save you waiting for another answer on the forums.
Hope this helps,
Cobra
Nintendo 3ds slashes price to 169.99 usd
By yoda313 in forum Off topicReplies: 0Last Post: 31st Jul 2011, 08:35 -
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 15:09 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 20:33 -
TMpegEnc DVD Author won't fill a 4.7 GB DVD
By jagojon3 in forum Authoring (DVD)Replies: 12Last Post: 29th Dec 2008, 18:32 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 01:23
