Hello all,
A friend of mine is ripping a couple of selected scenes from movies using dvdshrink and then recoding them to avi using autoGK. The plan is to have a bunch of short video clips along with a bunch of wma cd tracks play randomly on the big screen. The problem is that the audio on the ripped avi's is sooo much quieter than the CD audio. You have to turn the volume up pretty high to hear the avi dialogue and then when it jumps to cd audio the volume is blaringly loud.
Is there any way to adjust the avi volum from within autoGK or even normal GK so that we don't have this problem?
Thanks in advance,
Russell
I don't think that there's a way this can be done since it uses an encoder that's automated for the audio. However, since it doesn't mux the audio until the end, you can take the resulting MP3 and work with it when AutoGK is working with the video.
Use a package like Audacity to boost the volume up, and save it. Don't touch anything else incase it changes the timing and puts the file out of sync.
It's a crude method but it should work, unless someone else has a more elegant solution.
Cobra -
Thanks for the reply!
I'll give that a try and see if I can get it working.
Russell
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
VOB2MPG Quiet Audio
By gfinlay in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Apr 2010, 03:28 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 04:57 -
Problem ripping a movie to avi with AutoGK, fast motion audio/video
By Mr. SoAndSo in forum DVD RippingReplies: 1Last Post: 7th Oct 2008, 11:57 -
Problem ripping a movie to avi with AutoGK, fast video/audio
By Mr. SoAndSo in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2008, 11:54
