How many times we can rewrite a DVD+RW disc. Say a TDK disc which I believe is better quality than others.
Results 1 to 15 of 15
if you believe the vendors...about 100,000 times (100 times more than CDRW). horror stories here would have you believe differently. some users state their dvdrw failed after as little as 3 months. personally all mine are still fine (Verbatim MCC) after about 6 months and as many as 8 rewrites.
Originally Posted by dvdplusrw.orgYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Originally Posted by mrinalkar
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
Those numbers are for ideal conditions, no durt, no scratches, no high temp storage etc.
But if you take care of your DVD's and you buy good ones then the amount of times you can rewrite it isn't something you should worry about. -
My Imation DVD+RW's have 50-75 rewrites and still going strong. My HP DVD+RW has 200-250 rewrites with no errors.
makntraks, I agree. If it work atleast 20/30 times then it is sufficient for me. I think the quality will also be same for R and RW.
Just my opinion-> I will spend $10 more to get 50 pack RW rather than R.
Originally Posted by Almost Human
Somewhere around here I have five Memorex DVD+RW discs that I've been doing write/erase cycles on for the last few months. I think the last time I checked they were over 300 rewrites each. I know that they were easily over 250...
I also have (finally) a Verbatim DLP DVD+RW disc that my Optorite will actually burn. It's already up to 70 write/erase cycles without any problems. -
Originally Posted by Hardcoreruss
Now thats interesting!You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Don't you just love typos?
Hey, wait a minute. He's talking about TDK +R discs, and everybody knows that's the choice of warez pirates for moving their movies from thevalentipirates.com to DVD.
WAREZ WHORE!:P
Originally Posted by 888888
The actual number depends however both on the writer and the discs. A German magazine (C't) made a test a while ago and I think some discs survived >1000 rewrites while some discs were not even close to reach 1000 rewrites. -
Originally Posted by indolikaa
Sorry meant -rw
Did not want to advocate anything -
That's good. I thought you might be 'Advocating Warez' or something like that.
hi-8 tapes to DVD with insane run times...
By paperhearts in forum Video ConversionReplies: 2Last Post: 9th Jan 2011, 08:28 -
DVD Decrypter, AutoGK and Subtitle Times
By sambat in forum Video ConversionReplies: 5Last Post: 13th Feb 2010, 06:55 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Burn AVI Video to DVD at different times onto one DVD
By 98xlt98 in forum Video ConversionReplies: 2Last Post: 18th Mar 2008, 08:58 -
Should the audio and video times match in DvD Lab?
By janeydoll in forum Authoring (DVD)Replies: 14Last Post: 9th Jun 2007, 13:45
