  1. Okay, I've authored several DVD's, and none of them are all that big (1 gig average), so to save money, I use DVD2One's join feature to put them all into one. Only trouble is, I have no idea how it does it, but when I do, all three files play perfectly, with no sync issues, but when the VOB's all get mixed together, sync issues galore come up, usually the first part of it looks good, but it gets progressively worse.
    Any pointers? Or should I just author them as separate chapters in Sizzle? The Join feature is nice because if I need a slight compression to fit the DVD, it does it, but if it causes problems, the heck with it!
  2. Master of my domain thoughton's Avatar
    England
    What does "when the vobs get all mixed together" mean?
    Tim Houghton
    Website • Photography
  3. by mixed together I mean 2 separate VIDEO_TS folders being merged into one, the join feature seems to merge the VOB's.
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    as long as you have valid VIDEO_TS folders it should not be a problem
    but to me it sounds like you are making the VIDEO_TS folders with something [ie sizzle] so why not just make the entire dvd with the app?
    since you are having problems with dvd2onex's join on these folders.
    just my 2cents
    per the compressoin, i usually always have sizzle put out slightly more than 4.4 and dvd2one will do a disc copy of this with no problems
