I'm looking to capture my VHS tapes as well as my Camcorder tapes so that I can convert them to DVDs. I have a Sony DCR-IP5 MicroMV HandyCam. Is this possible to do with my camcorder?
It is my experience (ip7bt) that you can capture to tape only. No direct passthrough capability. You use the same cable you use to play to a tv, and you set the mode in one of the menus.
Your bigger problem will be getting it from the cam to the computer. I've had to send mine back to sony because the capture over firewire doesn't work for me. I've tried Studio 8 and the movieshaker software, with no consistent luck.
There is a lot of complaints about similar problems and a great source of info about these cameras at http://www.vaiovillage.com/
Good luck.
ar
want too capture movies from analog camcorder into computer
By shashgo in forum Capturing and VCRReplies: 3Last Post: 7th May 2012, 07:19 -
Capture analog with camcorder or ATI card?
By Onceler2 in forum Capturing and VCRReplies: 7Last Post: 28th Nov 2009, 08:25 -
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 17:39 -
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 15:32 -
Urgent Question Sony CCD-TRV438E Hi-8 Analog Camcorder
By Shaga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 14:32
