hi all, i am trying to compress footage using premiere , but when it is done
there is something wrong like a pulse which appears every second or something, does anyone knows why this happens and how to fix it.
i am using MPEG4 codec
thanx in advance
What Mpeg4 codec/settings are you using?
This can happen if you have the quantizer offset between I frames and B/P frames too large. You end up getting a quality "pulse" everytime a new I frame plays.
-Suntan -
hi Suntan, thanks for replying, this are the settings of the compressor
shown in the attached pic, i dont know about the "quantizer offset between I frames and B/P frames " , plz make it in details..
I have never used "Microsoft MPEG-4 Video Codec V3" so I can't really give you specifics, but at 3Mbits/s you shouldn't be having the problems I am talking about. Unless your video stream is Hidef or something (1080P)
maybe someone else has an idea. -
Your using an FPS of 15.
Unless the original is 15 FPS, you'll notice a "pulse" by changing the frame rate. Keep the same output frame rate as the input frame rate.
Split recording a continuos live stream
By GordonFreeman in forum Video Streaming DownloadingReplies: 3Last Post: 29th May 2010, 20:09 -
Better Compression?
By anirban in forum Video ConversionReplies: 20Last Post: 5th Oct 2008, 18:19 -
Problem with Pink Floyd Pulse DVD
By altsouza in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 19:48 -
Continuos DVD problems
By jbartosh in forum Authoring (DVD)Replies: 18Last Post: 4th Feb 2008, 15:30
