i have just captured a 35 second clip using adobe premiere and it saves it as a 125 Mb .avi file.
i then go to export it as a divx file and the conversion goes through but i end up with an 18 Mb file that looks very bad (lines on and off, etc...)
any ideas what i should set it too, or how i can convert it to divx better?
i can't seem to be able to use VirtualDub 1.4.7 for the conversion since it can't open the .avi file created by premiere on capture. it complains that it "couldn't locate decompressor for format 'dvsd' (unknown)"
any help would be apreciated. either with getting virtualdub to convert or with premiere settings.
Your captured source is probably interlaced so then should you use a deinterlace filter in premiere when saving as divx.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Adobe Premiere Capabilities
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2007, 17:18 -
Working with converting using tmpgence and adobe premiere pro 2.0
By Dante016 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 21:56 -
Adobe Premiere Pro & Burning DivX
By epsilon9090 in forum Authoring (DVD)Replies: 9Last Post: 22nd May 2007, 16:42
