Hey guys,
I encountered a problem with MMC - the capture function is in disabled/invisible mode on the TV display.
Haven't done any recent installation or made any changes, other than the drive being full.
Wondering if it's a driver issue and what I can do to get it corrected.
I'm able to play both audio and video and no problem doing still captures - it's just capturing video that for some reason I'm not able to do.
It worked fine for a few months prior.
Should I re-install MMC or is there another way around it?
You can probably thank Windows for screwing up the drivers, especially if the drive filled up an made the swap go all wacky to find space in all the fragmented gaps.
I'm sure there's lots of thing to play with, and hours to do it in.
Quick answer: remove EVERYTHING related to ATI (drivers, display stuff, MMC, etc) ... and re-install.
Also, try to put on 8.9 while you're at it (if you're using an old one), and see if it'll catch. Since you've got to tear it apart anyway, may as well look at trying the upgrade.Want my help? Ask here! (not via PM!)
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 11:13 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
