a small percent of my dvd-r's jerk.
it could be at the start middle or end.
its not the way i encode or author as other dvd-r's of the same movie (home movie of course) work perfectly.
i make sure i have no programs running other than what windows runs automatically.
could it be bad media?
most likely. what kind of media are you using?
i would recomend ritek's myslef. you can also try to slow down the burn to 2x or 1x and see if that helps -
bulkpaq dvd-r 4x aka princo
it's only a small percentage, i find them very compatible and cheap
it's just the fact that i'm not sure if it is media or something else that's bugging me -
Thats probably a media issue. Try to burn slow, and keep the total size under 4GB.
yes princo's have been known to cause many problems. i would highly suggest using a different brand than princo
Trouble playing ripped DVD with Windows Media Center 2005-bad country code
By nzdreamer55 in forum DVD RippingReplies: 3Last Post: 6th Mar 2010, 11:28 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad DVR-MS files with Vista Media Center
By waxtadpole in forum Media Center PC / MediaCentersReplies: 6Last Post: 13th Dec 2008, 17:50 -
Blu-Ray Media - Who's good and Who's bad.
By SCDVD in forum MediaReplies: 1Last Post: 23rd May 2008, 04:58 -
Bad DVD media
By PhoneMatt in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 12:01
