  1. I currently backing up my daughter dvd's and running into problems at least 50 percent of the time I get a atapi error within the first few seconds of the burn,, rendering the disk useless I included the full log
    can anyone help.
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 12/22/1997 6:23:24 PM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
    Nero API version: 6.3.0.2
    Using interface version: 6.0.0.0
    Installed in: C:\Program Files\Ahead\Nero\
    Application: ahead\Nero - Burning Rom
    Recorder: <HL-DT-ST DVDRAM GSA-4081B>Version: A100 - HA 1 TA 0 - 6.3.0.2
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    === Scsi-Device-Map ===
    DiskPeripheral : Maxtor 6Y060L0 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : HL-DT-ST DVDRAM GSA-4081B atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : LITEON DVD-ROM LTD163 atapi Port 1 ID 1 DMA: On
    CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 2 ID 0 DMA: Off
    === CDRom-Device-Map ===
    HL-DT-ST DVDRAM GSA-4081 D: CDRom0
    LITEON DVD-ROM LTD163 E: CDRom1
    AXV CD/DVD-ROM F: CDRom2
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 1023MB (1048048kB)
    Free physical memory: 650MB (665776kB)
    Memory in use : 36 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    6.5.2004
    NeroAPI
    10:02:48 PM #1 Phase 111 File APIProgress.cpp, Line 253
    DVD-Video files sorted
    10:02:49 PM #2 Text 0 File Reader.cpp, Line 118
    Reader running
    10:02:49 PM #3 Text 0 File Writer.cpp, Line 124
    Writer HL-DT-ST DVDRAM GSA-4081B running
    10:02:49 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
    First writeable address = 0 (0x00000000)
    10:02:49 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3882
    10:02:49 PM #6 Text 0 File Burncd.cpp, Line 3101
    Turn on Disc-At-Once, using DVD media
    10:02:49 PM #7 Text 0 File DlgWaitCD.cpp, Line 240
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2286223 (508:02.73, 4465MB)
    10:02:49 PM #8 Text 0 File DlgWaitCD.cpp, Line 245
    Write in overburning mode: FALSE
    10:02:49 PM #9 Text 0 File DlgWaitCD.cpp, Line 2085
    Recorder: HL-DT-ST DVDRAM GSA-4081B, Media type: DVD-R
    Disc Manufacturer: ONIDTE - CH
    Disc Application Code: 64, Disc Physical Code: 193
    10:02:49 PM #10 Text 0 File DlgWaitCD.cpp, Line 406
    >>> Protocol of DlgWaitCD activities: <<<
    10:02:49 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2286224 (2286224) = #2286224/508:2.74
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286224 blocks [HL-DT-ST DVDRAM GSA-4081B]
    10:02:49 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
    Prepare recorder [HL-DT-ST DVDRAM GSA-4081B] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682186752, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2286224 | lead-out | 1 | 0x00 | 0x41
    10:02:50 PM #13 Phase 24 File APIProgress.cpp, Line 253
    Caching of files started
    10:02:50 PM #14 Text 0 File Burncd.cpp, Line 4073
    Cache writing successful.
    10:02:50 PM #15 Phase 25 File APIProgress.cpp, Line 253
    Caching of files completed
    10:02:50 PM #16 Phase 36 File APIProgress.cpp, Line 253
    Burn process started at 2x (2,770 KB/s)
    10:02:50 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    10:02:50 PM #18 Text 0 File DVDR.cpp, Line 1512
    Recording mode: Sequential Recording Mode
    10:02:50 PM #19 Text 0 File Mmc.cpp, Line 19451
    Set BUFE: supported -> ON
    10:02:50 PM #20 Text 0 File DVDR.cpp, Line 1643
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    10:02:50 PM #21 Text 0 File Cdrdrv.cpp, Line 7941
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26127F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    02 FE 10 00 02 FF A0 00 - 00 00 00 00 00 00 00 00 ................
    10:03:11 PM #22 SCSI -1135 File Cdrdrv.cpp, Line 1431
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x013E0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
    0x32 0x4D 0x03 0x0C 0x0C 0x00
    10:03:11 PM #23 CDR -1135 File Writer.cpp, Line 301
    Write error
    10:03:11 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    10:03:11 PM #25 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    10:03:11 PM #26 Text 0 File DVDR.cpp, Line 1847
    EndDAO: Last written address was -1
    10:03:13 PM #27 Phase 38 File APIProgress.cpp, Line 253
    Burn process failed at 2x (2,770 KB/s)
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 12/22/1997 7:02:46 PM
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Try putting your LG as Secondary Master with the liteon as secondary slave.
  3. Tks for you reply,, the drive was on secondary Master, however the point is now mute, not two days after I posted this, the drive stop working altogether. I am getting it exchange on warranty as we speak.
