Hello, im new at making DVDs, i use TMPGEnc to convert it to DVD and then i use TMPGEnc DVD author + burner to burn the DVD, eveything works fine ecept when i want to put a full movie on a DVD there is not enough space. I read other threads where they say there are different MODEs of burning just like SP, LP on VHS but i dont know how to do that... the minimum bitrate using TMPGEnc is 2000 and thats still too much for one DVD. Even as everything set to the lowest quality in TMPGEnc a 1:40 movie is too larg for one DVD... how do i fix this?
(should i convert it anyways and there is a way to fix it later, or do i have to do something with TMPGEnc?)
thank you.
(i know there is another thread asking hte exact samething and i read the whole thing but didnt undrestand a thing... if possible could you please try to explain it as simply as posible, thanx)
Results 1 to 10 of 10
Is your source file an avi or a dvd ?
its avi
[EDIT] oh... no i never actually converted because tmpgec said it wouldn't fit on a dvd...
but the movie is 1hr and 40min. -
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Tmpgenc MUST get the runtime incorrect, 1.40 SHOULD fit.
Read: www.videohelp.com/tmpgenc#problems . -
If TMPGEnc says that the video time / runtime is way too long
TMPGEnc keeps encoding after the end of video with only a black screen
Try change the directshow reader priority, in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and reopen the video.
If that doesn't help try convert the audio to WAV audio before converting and use the wav as audio source.
And if all that didn't help you can always use the source range to select exact what to encode, under Settings->Advanced in TMPGEnc.
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 30th Oct 2008, 00:58 -
makin the movie fit
By xstatictravis in forum DVD RippingReplies: 12Last Post: 11th Apr 2008, 09:52 -
makin a movie fit?
By xstatictravis in forum Authoring (DVD)Replies: 1Last Post: 8th Apr 2008, 21:30 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18
