    Apr 2004
    tasmania
    does anyone know how to centre the label onto a cd stomper pro cd labelling system template before printing??? mine are always skew wiff.
    thanks
  2. Before you go on and start using a CD stomper, do you realize how bad this is for your disc and the players that will be reading them? Discs, while being read, spin quite fast and the slightest weight issue, whether it be the misdistribution of weight or just plain being too much of it can cause damage to your readers over time. Though it looks far prettier than a Sharpie, it might not be worth it in the long run.
    Apr 2004
    tasmania
    thanks, have read that same thing in the forums, just wish I knew that before i purchased 200 of them!!!!! Will use these up then get a sharpie
