I see that Mainconcept have nearly got their H264 encoder ready. The origional specs for H264 were claiming a 30% reduction in size for the same quality as H263.
What is the internal differences?
Will we be seeing a H264 version from Divx or Xvid or Nero?
Wait. I'm confused. H263 is an encoder engine.
DivX and XviD are avi codecs.
Nero is a burning application (with a completely different encoder in the associated apps).
Comparing Nero to Mainconcept (encoders) is like a Tonka truck vs. a Peterbuilt.Cheers, Jim
My DVDLab Guides -
mikesbytes,
Reboot really does appear to be confused. H.264 is the ITU-T specification for MPEG 4 compression. I don't know if Nero, Divx, and Xvid fully support the spec, but they all already have MPEG 4 encoding.
[edit]
Sorry, forgot to mention that h.263 is an older spec for low resolution video -- typically used for web cam type video.
mp4 xvid vs H264 mpeg-4 avc quality difference
By johnharlin in forum Video ConversionReplies: 2Last Post: 8th Apr 2012, 07:38 -
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 15:44 -
Divx or xvid? Whats the difference?
By szalaikornel in forum Video ConversionReplies: 3Last Post: 17th Jan 2009, 12:16 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 23:15 -
whats a good program to use to convert/compress to h264
By cowboysroy31 in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 18:28
