Hi,
I've created a VOB file out of a VIDEO_TS with extractor. The VOB file contains both the interactive presentation and the movie (i've only ripped off extra contents).
Then, i've tried to requantize this VOB file with the dvd9-dvd4 tool of ffmpegx, choosing only the audio track #2 (french one). The process produce a .ac3 file, then a .m2v file but fails with the following messages. (A 350MB .mpg file is also produced, which contains the interactive menu, but with the beginning of the movie soundtrack).
For the record, i wanted to get à 4GB DVD with the interactive menu and the french version of the movie (don't know if it's even possible, though).
Anyway, here the log:
M2VRequantiser by Makira.
Using 1.541481 as factor.
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/Vrac/VTS_06_0.VOB.vob.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/Vrac/VTS_06_0.VOB.vob.ac3 looks like an AC3 Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Vrac/VTS_06_0.VOB.vob.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 16:9 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 9800000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: AC3 Audio stream 00 (/Volumes/Vrac/VTS_06_0.VOB.vob.ac3)
INFO: [mplex] AC3 frame size = 768
INFO: [mplex] AC3 AUDIO STREAM:
INFO: [mplex] Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 10147800
INFO: [mplex] target data-rate specified : 10080000
++ WARN: [mplex] Target data rate lower than computed requirement!
++ WARN: [mplex] N.b. a 20% or so discrepancy in variable bit-rate
++ WARN: [mplex] streams is common and harmless provided no time-outs will occur
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16619
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio bd: buf= 16384 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 17432
INFO: [mplex] Running out...
INFO: [mplex] Video e0: buf= 197248 frame=017432 sector=00173891
INFO: [mplex] Audio bd: buf= 1507 frame=021774 sector=00008295
**ERROR: [mplex] Need to split output but there appears to be no %d in the filename pattern /Volumes/Vrac/VTS_06_0.VOB.vob.4.mpg
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
Having problems converting a dvd9 to a dvd5 DVD (PC keeps rebooting)
By tfoster in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2009, 15:38 -
Can I copy a DVD9 to a DVD4??
By hzgg2 in forum DVD RippingReplies: 1Last Post: 10th Oct 2008, 15:56 -
Problem with dvd4 tool
By barskey in forum ffmpegX general discussionReplies: 2Last Post: 5th May 2007, 21:32
