am having strange prob with stomp When Ive used cheap pcline disks its copied perfecly and worked on my dvd player. Now ive finally got some ritek the bloody dvd player doeesnt even recognise it as a dvd it just asks u to insert the disk. Infact i am currently using nero which seems to burn them fine for my player. i have a cyberhome dvd player and up until nowit has even played a slice of toast.Ironically these discs that dont work on mine tend to work fine on my mates player which in the past has practically rejected everything ive ever burnt for him.
i swear ive not changed any settings.
any ideas?
i was looking up from my bed at the stars when i wondered....Where the hells my ceiling?????
You changed from + to - media by any chance ?
Not bothered by small problems...
Spend a night alone with a mosquito -
hi guys and thanx for your help so far.
no i havent changed my media and i will go to my other machine and uncheck the cheap media icon on nero. I just would like to know what does that do?i was looking up from my bed at the stars when i wondered....Where the hells my ceiling????? -
OK, seriously God only knows what the issue is. You need to find media and burning method that all your gear is happy with. No other way. Riteks play great on some and fail on some other. There is no silver bullet. Try few other brands until you're happy with the results.
