Hello,
I'm using winfast 2000 delux to cap but can't figure out which setting to enter in TMPGEnc for the video source type (feild order) ???
encode is for playing in standalone DVD player on TV.
thanks,
James.
I use Upper (TOP) Field First (Field A), but I came to that conclusion after creating a dvd with 2 identical video clips on it (labeled of course) in each of the field orders and tested that on my TV. Field A played normal while Field B 'jittered' expecially during pans and shots with quicker movements.
It's going to depend on your setup and tv, but 'probably' field A will work.
You need to test that. lol
Also, when I use any Ulead product except VideoStudio Version 8 (the newest version) I must choose Field B, but all the other programs I have reports their files as Field A. Now that's confusing isn't it. lol
Good luck. -
OK thanks - I'll use A (and test out B too).
would the 'video source type' be 'non-interlace (progressive)' or 'interlace' ?
James. -
I think that sets itself, doesn't it. I don't actually remember, but I think it's a no brainer there.
Correct me if I'm wrong ok.
Good luck -
I've managed to do 4 samples [non-interalced a & b] then [intelaced a & B].
both b's are jerky - so that leaves [non-interalced a] & [intelaced a] nothing appears to be different on play back with either setting!
I'll go with (unless told othewise here) interaced - that seems to be the default when staring & loading my file in Tmpgenc.
cheers,
James. -
Good deal. Now you know for sure.
Interlaced video is ment to be played on a TV set. That's what is coming across the cable now so that is what you want to create.
Non-Interlaced (frame based) video is what you would create to playback on a computer monitor only.
Non-interlaced video played on a TV will showup most as uneven (jagged) lines on straight edges.
Good luck.
DGIndex says 100% Video, but MeGUI Avisynth analysis says Source Type Film
By Simcut in forum DVD RippingReplies: 11Last Post: 9th Mar 2012, 16:10 -
What type of light source are you using in your home?
By johns0 in forum PollsReplies: 15Last Post: 9th Dec 2011, 11:33 -
S-Video Source/Signal Type Question
By generallee in forum Capturing and VCRReplies: 2Last Post: 23rd May 2011, 03:31 -
Field Order When Converting HD source to DVD
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2008, 01:22 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 13:48
