i need a simple DV editor, simply to chop down the size of captured DV files that i have captured with my canopus, whats the best and EASIEST program to use,![]()
Check out a new guide posted to this site today:
http://www.doom9.org/index.html?/dv/guide.html
It covers your question and more.
I have several available because they come as bundled with hardware. I usually use Pinnacle Studio 8.12. Then I save back as a DV file and bring into TMPEGEnc for encoding, and then to TMPEGEnc DVD Author to author. -
i cant get virtual dub to open my captured file, it says it cant locatate decompressor for format "DVSD" any one help me with this??? it also says it needs a VFW video for windows compatibel codec ,
You need a DV codec to open the file in Virtual Dub.
Have a look in the tools section under codec's. -
Be careful when choosing what codec to use for your DV files. There are 3 of them I think and all of them handle noise differently. Read about it over at http://forum.doom9.org/showthread.php?s=e5216561e5c9b265ff3c58ac714d20d9&threadid=33526
As Beavis and mikesbytes said: Virtualdub. Try the Panasonic codec and VD will see the file.
Originally Posted by efiste2
In my opinion, VirtualDub is not the easiest or the best for a newbie to do these things.
VirtualDub however is the easiest and the best for a newbie for post processing (applying filters, resizing and frame serving to an encoding program).
Simple Xvid AVI editor?
By tonut in forum EditingReplies: 10Last Post: 12th Jan 2011, 06:10 -
simple free editor to spilt up my MPG2 file?
By Bansaw in forum EditingReplies: 1Last Post: 6th Jul 2009, 09:24 -
Can't find a simple video editor.
By A Traveller in forum EditingReplies: 17Last Post: 28th Mar 2009, 19:05 -
Need a SIMPLE editor for adjusting brightness, etc.
By coyotewrw in forum EditingReplies: 8Last Post: 19th Nov 2007, 11:49 -
Simple Video Editor?
By lilmetal in forum EditingReplies: 16Last Post: 22nd Aug 2007, 20:55
