1. When I add video as a motion background for one of the menus, I get several vertical white lines that keep flickering over the video. Anyone have any experience with that?
2. I got the root menu created just fine. On the root menu, I have a button that takes you to a video and another that takes you to a slide show.
The menu button for the video takes you to a CHAPTER MENU. How can I change this so it automatically starts the video? I STILL want the chapter menus, but want the pressing of the button to go right to the video, and IF they want they can go to the chapter menu and select different parts to watch
Thanks all!
1. Could possible be the way the video is encoded. Does the video do that when played alone (outside of UDWS).
2. Create a Button for play, then drop the video from the right side video list on it. You would also need a separate button linked to the chapter menu. -
The video does not do that when I play it regularly. Only when it is being used as a motion background for the menuOriginally Posted by Supreme2k
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 23:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
